I have AXC2152. I installed Node.js from the plcnext store, node-red , then wanted to install OPC UA IIoT node on node-red but knew about the problem of compiling the package in native. So I followed Bjorn article about installing GNU Guix package manager but relied mainly on the script which did all steps. However, the environment variables have to be set everytime I login as “root”. I installed make, python, and GCC and suffered till I was able to use python 2.7 in npm command. Now when I try running command “npm install -g bcrypt”, there is error that it can’t find make despite I can run make from command line. I am not that knowledgeable in linux and ofcourse new to PLCnext so appreciate your help
node-pre-gyp WARN Using needle for node-pre-gyp https download
node-pre-gyp WARN Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v3.0.6/bcrypt_lib-v3.0.6-node-v64-linux-arm-unknown.tar.gz
node-pre-gyp WARN Pre-built binaries not found for bcrypt@3.0.6 and node@10.15.3 (node-v64 ABI, unknown) (falling back to source compile with node-gyp)
gyp WARN EACCES user “root” does not have permission to access the dev dir “/home/root/.node-gyp/10.15.3”
gyp WARN EACCES attempting to reinstall using temporary dev dir “/opt/plcnext/appshome/data/60002172000051/lib/node_modules/bcrypt/.node-gyp”
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at getNotFoundError (/opt/plcnext/apps/60002172000051/opt/node-v10.15.3-linux-armv7l/lib/node_modules/npm/node_modules/which/which.js:13:12)
gyp ERR! stack at F (/opt/plcnext/apps/60002172000051/opt/node-v10.15.3-linux-armv7l/lib/node_modules/npm/node_modules/which/which.js:68:19)
gyp ERR! stack at E (/opt/plcnext/apps/60002172000051/opt/node-v10.15.3-linux-armv7l/lib/node_modules/npm/node_modules/which/which.js:80:29)
gyp ERR! stack at /opt/plcnext/apps/60002172000051/opt/node-v10.15.3-linux-armv7l/lib/node_modules/npm/node_modules/which/which.js:89:16
gyp ERR! stack at /opt/plcnext/apps/60002172000051/opt/node-v10.15.3-linux-armv7l/lib/node_modules/npm/node_modules/isexe/index.js:42:5
gyp ERR! stack at /opt/plcnext/apps/60002172000051/opt/node-v10.15.3-linux-armv7l/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
gyp ERR! stack at FSReqWrap.oncomplete (fs.js:153:21)
gyp ERR! System Linux 4.14.63-rt40-pxc
gyp ERR! command “/opt/plcnext/apps/60002172000051/opt/node-v10.15.3-linux-armv7l/bin/node” “/opt/plcnext/apps/60002172000051/opt/node-v10.15.3-linux-armv7l/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “build” “–fallback-to-build” “–module=/opt/plcnext/appshome/data/60002172000051/lib/node_modules/bcrypt/lib/binding/bcrypt_lib.node” “–module_name=bcrypt_lib” “–module_path=/opt/plcnext/appshome/data/60002172000051/lib/node_modules/bcrypt/lib/binding” “–napi_version=3” “–node_abi_napi=napi” “–napi_build_version=0” “–node_napi_label=node-v64”
gyp ERR! cwd /opt/plcnext/appshome/data/60002172000051/lib/node_modules/bcrypt
gyp ERR! node -v v10.15.3
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
node-pre-gyp ERR! build error
GSDML-V2.33-PhoenixContact-GWPNASCII-20171001 - EDIT (2).zip
