Error uploading an staring application
I’m getting the following error when trying to write and start my application :
Plc failed: ‚Exception occurred: ‚Could not get IGdsProxyComponentServicePtr for process ‚‘‘‘ - at component Arp.Plc.Gds on SetupPlc(isChanging=false, startKind=Warm)
Any idea what is going on?
Greetings
Wim
Which PLCnext Engineer version and PLC FW version are you using? does this also happen with other PLCs or just this one? have you tried a type 1/type 2 reset for the PLC?
I haven’t seen this issue yet, if it happens with every PLC or does not get solved by a type 2 reset or a FW update to the latest version then we will require your project so we can reproduce this issue ourselves. For this you can contact your local support (Belgium axsupport@phoenixcontact.be or the general be-info@phoenixcontact.com and they will forward it the right people)
kind regards
