Is it possible to activate eth1 on the controller to have 2 Ethernet connections. Reason for this need is to set up a VPN connection with one WAN and one LAN port.
Regards
Dan Møller PxC Denmark
Regards
hello Dan, you can add multiple IPs /Subnets to one port.
just configure /etc/network/interfaces
for example like this. #Lokales Netz
auto eth0
iface eth0 inet static
address 10.250.143.10
netmask 255.255.255.0
gateway 10.250.143.1 #Zweite IP des lokalen Adapters
auto eth0:0
iface eth0:0 inet static
address 192.168.1.110
netmask 255.255.255.0the controler has only one ETH adapter. both ports are switched.
Some time in the future we will supply a module that can be placed on the PCIe Bus of the AXC F 2152 (on the left) with this it will be possible to physically seperate networks…
please note Vincents concerns regarding network security!
Hi Dan, As Oliver said, it is possible but please be aware that: I you connect the controller to the WAN, you will also be able to reach it from the internet. This could have some unintended side-effects:
* Any applications you install yourself, without proper security-configuration will respond to request from malicious actors
* Spoofed traffic (e.g. UDP) from internet would be able to reach LAN-services on the device
* Spoofed traffic (e.g. UDP) from internet can access you LAN devices as well
So keep these considerations to mind Cheers, Vincent
* Any applications you install yourself, without proper security-configuration will respond to request from malicious actors * Spoofed traffic (e.g. UDP) from internet would be able to reach LAN-services on the device * Spoofed traffic (e.g. UDP) from internet can **access you LAN devices** as wellSo keep these considerations to mind Cheers, Vincent
Hi all, I’ve added a second address on the same network. But the second address does not answer to any ping request (did a power down-up): Firmware 2021.0.3 Config: # The loopback interface auto lo iface lo inet loopback # Wired or wireless interfaces auto eth0 iface eth0 inet static address 10.0.6.50 netmask 255.255.0.0 gateway 10.0.0.1 dns-nameservers 8.8.8.8 8.8.4.4 auto eth0:0 iface eth0:0 inet static address 10.0.6.51 gateway 255.255.0.0 auto enp1s0 iface enp1s0 inet static address 192.168.2.10 netmask 255.255.255.0 gateway 192.168.2.1 dns-nameservers 8.8.8.8 8.8.4.4 Ping Pinging 10.0.6.50 with 32 bytes of data: Reply from 10.0.6.50: bytes=32 time=2ms TTL=64 Reply from 10.0.6.50: bytes=32 time=2ms TTL=64 Reply from 10.0.6.50: bytes=32 time=2ms TTL=64 Reply from 10.0.6.50: bytes=32 time=2ms TTL=64 Ping statistics for 10.0.6.50: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 2ms, Maximum = 2ms, Average = 2ms C:\\Users\\gdogger>ping 10.0.6.51 Pinging 10.0.6.51 with 32 bytes of data: Request timed out. Request timed out. Request timed out. Request timed out. What could be the issue?
