As mentioned in the PLCnext Technology User Manual, there are Alarm function blocks mentioned for the PLCNext Engineer, unfortunately I was unable to find those in the Programming components… Could you tell me whether I am missing something out, or is it a not-yet-implemented feature inside the PLCNext Engineer? In my use-case, I want to use the alarms signaled by the C++ libraries (managed to get it to work with the C++ code) to communicate a critical state of the system to the operator via the eHMI interface. Do you think, that there could be a way to facilitate this if the Alarm block are really missing out from the PLCNext’s IEC61131, if possible I would prefer to avoid using additional GDS ports.
Kind regards,
Michael Czorniej
