Firmware update from version 2021.0.3 LTS to 2023.0.0 LTS
I want use Codesys v3.5 runtime on my PLCnext controller but
i can’t update firmware from 2021.0.3 LTS to 2023.0.0 LTS via WBM
firmware is allways unchanged stays on 2021.0.3 LTS version after reboot.
Where is the problem?
Dear Ivan,
you have to Upgrade to 2022.x.x Firmware First. A direct Update from 2021 to 2023 ist Not possible
No. Thanks for info!
I try to update to 2022.0.8 LTS but it failed?
Firmware is still old one 2021.0.3 LTS
Can you confirm that you are using the procedure described on this page to upgrade the firmware to version 2022.0.8 LTS?
Administration - Firmware Update In order to update to firmware version 2023.0 LTS or newer at least a firmware version 2022.0 LTS or newer must be installed on the controller. Firmware versions 2021.9 and before will not accept the *.raucb firmware update file. If that does not work, please try this procedure:
Copy the .rauc file for firmware version 2022.0.8 to the opt/plcnext directory on the controller (e.g. using WinSCP or just scp
* on a Windows command line) .
* Start an SSH connection (e.g. with Putty or just ssh on a Windows command line) and enter the following command: sudo update-axcf2152
Please take note of any error messages that appear.
If the procedure is successful the controller should reboot and the new firmware version should be installed.
Can you confirm that you are using the procedure described on this page to upgrade the firmware to version 2022.0.8 LTS?</p>[https://www.plcnext.help/te/WBM/Administration_Firmware_Update.htm</a></p>If that does not work, please try this procedure:</p>
* Copy the `.rauc</code> file for firmware version 2022.0.8 to the `opt/plcnext</code> directory on the controller (e.g. using WinSCP or just `scp</code> on a Windows command line) .</li>
* Start an SSH connection (e.g. with Putty or just `ssh</code> on a Windows command line) and enter the following command: `sudo update-axcf2152</code></li></ul>Please take note of any error messages that appear.</p>If the procedure is successful the controller should reboot and the new firmware version should be installed.</p>
Thanks for answer. I didn’t manage to update firmware to newer version throught WBM but suddenly I don’t know
how I manage to install Codesys Run time on PLCnext cotroller without error: update your firmware.
