I want to upgrade the firmware of my PLC from the 24.0.0 to the 24.0.6 version. I did install the firmware version and unzipped it. Now When I click on Start update I get the following error.
What does this mean and what should I do to fix this issue?
I do now see the user partition space but don’t know how I could remove space from the User Partition.
Hi!
Try to use du -hc /opt/plcnext via ssh terminal connection to analyze space consumption.
Free space via ssh or WinSCP after that.
BR
I logged in the shh terminal but how do I know which files I could remove? Could I remove everything or only specific files?
Hello Joep,
You can also make a clean install and perform a type 1 reset but then you also wipe your program, log files etc.
So you will have to download your project again.
Please check first if there is data on the controller you need to safe and transfer it before yo do the reset!
Met vriendelijke groet / Mit freundlichen Grüßen / Best regards,
Henk Welgraven
Technical Sales Engineer
Industrial Electronics
PHOENIX CONTACT B.V.
Postbus 246
6900 AE ZEVENAAR
Tel. +31 (0)316 59 17 20
mailto:support@phoenixcontact.nl www.phoenixcontact.nl
