I have this module, it is compatible with these function modules AXL F CNT2 INC2 XC 1F, it will be used to see the speed of a conveyor belt, the rpm (revolutions per minute), do you know if there is an example to do this integration, the plc axc 2152
Yes. Chapter 9 of the documentation that comes with that library gives examples of how to use the function blocks in that library.
Ok, the question would be if the block is compatible with the module, since in the examples they use this IB IL CNT-PAC (2861852), I have this AXL F CNT2 INC2 XC 1F and which module would I use to have the RPM, the revolutions per minute .
I’ve just checked with the developers of that library, and unfortunately the library is not designed for use with AXL F CNT2 INC2 XC 1F.
If there isn’t another suitable library in the PLCnext Store, then you will need to use the Process Data directly in the PLCnext Engineer project. The Process Data for the AXL F CNT2 INC2 XC 1F is described in detail in the User Manual for that module.
Maybe someone in the community has an example project that they can share with you. You can also contact the technical specialists in your local Phoenix Contact office, who will be able to give advice on your specific application.
