FW 2025.0 - Support of multiple subnets
Reading through the changenotes of FW 2025.0 I came across “Rework of network management”.
With the change of the Linux® initialization system (details see Changing the initialization system), the Linux® network management is also changed from the ifup/ifdown procedure with /etc/network/interfaces to the network management integrated in systemd via networkd.This change allows to implement functions such as multiple IPs per interface, multiple gateways, VLANs, and more in the medium term. It also increases the stability of the system when the IP is changed using Linux® tools.The network configuration is now handled by the networkd daemon, which is part of systemd. The Linux® tools ifup and ifdown no longer exist, and the file /etc/network/interfaces will no longer be evaluated. This affects all users who manually intervene in the network configuration via the /etc/network/interfaces file. How the conversion of the IP configuration is to be done can be found in the change notes for firmware 2025.0.If a user only uses Arp mechanisms for network configuration (e.g., PLCnext Engineer or the Web-based Management), no adjustments are necessary.So, If i understand this correctly, I can could have multiple IPs on the single ethernet interface (with 2 switch ports RJ45) of the AXCF 2152. So, currently the PLCs are located in 192.168.1.x subnet. I would like to have peripherals, that are connected to the PLC (Profinet), in the subnet 192.168.y.
So, I would need a second ip in a different subnet on the PLC-side.
Reading the network change notes, is that possible in the PLC Next Engineer & FW 2025.0?
Hello robin4clx,
thank you for your inquiry.
I understood it exactly as you did.
The changes apply to PLCnext Engineer 2025 and Firmware 2025.
If you start to edit settings manually on the Linux system you leave the PLCnext context. But there are some promising sources. For example this one: Migrating from Legacy Networking to systemd-networkd on Ubuntu 24.04 | End Point Dev
Alternatively, you can also consider using an intelligent switch and managing VLANs through it, for example.
OK, so please confirm, is it possible to configure it that way like I have described with PLCNext Engineer 2025 (and FW 2025.0).
I dont want to make changes the networking in linux. How can I setup the different ips?
Hello robin4clx,
there is no native solution from us.
Without making changes to Linux yourself, you will not be able to implement your solution.
