Gsdml
Hi I have to manage a Siemens Instrument (Sitrans) I have already imported the GSDML file I have added the device to the Profinet connection Now i dont know how to read and manage the value I have only to read the Level value, display it on the web panel and send to the cloud.
Hopefully you see something in the Data List tab. You should be able to connect the data in this Data List (OUT ports) to IN ports on your own program instance. You should be able to make these connections in the „PLCnext“ branch of the project tree, in the „Port List“ tab.
Could you please add the Siemens type number and the FW version? Without those information’s it is a guess work on what you work and we are not able to help you. Peter Paul
