Hi, i am new to PNE. I am trying to open Help. When i select “view help”, the moving disk appears like it is about to open something, then nothing happens.
I do not know if this is associated, but the same thing happens when i try and open WBM (Web based management)
Thank you for your feedback.
Ryan
Hi subcom,
that sounds like an issue with your internet browser. Which default browser do you use on your OS?
I, for example, use Edge and WBM/Help is opened as a new tab there.
Cheers
DivisionByZero
Hi subcom,</p>that sounds like an issue with your internet browser. Which default browser do you use on your OS?</p>I, for example, use Edge and WBM/Help is opened as a new tab there.</p>Cheers</p>DivisionByZero</p>
Thank you for the feedback X/0. My default is chrome. tried in edge and it worked. Thank you again.
