HMI - DropDown behavior
Hi!
I’ve a problem with the DropDown-Element in the HMI. Although i placed it in the top layer in the hierachy the elements to choose are behind the other elements as you can see in the attached files. What can i do?
Thanks!
![reihung.png](//discourse.plcnext-community.net/uploads/default/original/2X/7/7e1c9f304933e499c414de15ab4003865acffb46.png)The list is on the top layer!
![drop_down.png](//discourse.plcnext-community.net/uploads/default/original/2X/9/9201a06f5a70867cc57a94120a86bd050ffbeb31.png)The text elements are above the DropDown elements!
Hello!
Try to bind some kind of trigger for visibility dynamic of text inputs, while you are working with drop-down list.
Text inputs demonstrates upstart behavior as long as I know this IDE…
I have just been told by the HMI support team that this is a known issue, and it will be fixed in a future release of PLCnext Engineer.
