I just want to get the demo application on my starter kit - but the PLCNext store asks me for a device ID - where do I get it from ? Regards J. Just an update: found a sample project on the main starter kit side - but this can’t be imported (error messages from PLCNext Engineer 2019):
* was created using an older version
* error uncompressing the file
Hello, The device ID is a the long hexadecimal number - called the “Cloud UUID”, I think - on the side of the PLC. You can also find this ID number in the Web-based Management console (in the “Proficloud” section), which is easier to copy and paste to the Store. I’m guessing that the project you downloaded from our website was from the “PLCnext Starter Kit” product page. This project was developed for the old PC Worx Engineer, which is why you cannot import it in to PLCnext Engineer. I guess at some stage the website will be updated to include a project that is compatible with PLCnext Engineer. In any case, this is a different project to the Starter Kit Demo app on the PLCnext Store, which is loaded directly on to the PLC (not through PLCnext Engineer). If you would like a copy of the source code for the PLCnext Store app, I can put you in touch with the developer. - Martin.
Thank you - yes the source code would be helpful, as I want to understand how the project is build. This is more or less the reason to use a starteer kit - isn’t it ? btw: to use any project from the store I need to connect my PLC to the internet first - correct ? Any recommendation or tutorial for that ? Cheers Joerg
Hi Joerg, Community member Yuri Chamarelli has published an article on the Makers Blog about connecting a PLC to the internet: https://plcnext-community.net/index.php?option=com_content&view;=article&id;=322 The basic steps are:
1. Assign your PLC a spare IP address on the same network as your Internet router.
2. Use the IP addess of the Internet router as the "Gateway" IP address in the PLC.
If you are on a corporate network, then you should check these steps with your system administrator. - Martin.
