I have a network set up with 1-AXC F 3152 and 10-AXL F BK PN TPS, how can I configure the IP addresses and name of stations directly on the AXL F BK PN TPS.
Grateful for the attention.
I’m not sure that’s possible. If you set the IP address using something like NetNames, then I think the BK includes a Web-Based Management feature that you should be able to access using a browser. Otherwise, the BK is a Profinet device that should generally be configurable in the same way as other Profinet devices, i.e. the device is given a Station Name via DCP (using a tool like Netnames), and the IP address is then set by the Profinet Controller when it starts up.
Please get in touch with the technical experts in your local Phoenix Contact office for help configuring Bus Couplers like this.
