How to diagnostic axioline devices error
Sir, IF there is any error happened in axioline devices connected in plcnext controller, Is there any way to diagnostic axioline devices using PC worx Engineer software ?
Any methods similar like Diag + in PCWORX ?
Hello, In the next firmware release, Profinet network diagnostic information will be available through the PLC’s Web Based Management interface. There are plans to include Axioline diagnostics - similar to Diag+ - through WBM in a later firmware release. In the mean time, Axioline diagnostics are available from two sources: 1. The Output.log file in the directory /opt/plcnext/logs 2. Variables In the global variable table in the running PLCnext Engineer project. - Martin.
