Hello Community, I made a Library with one component and 2 programs. Now I want to remove one of them since it became obsolete but apparently removing the .cpp and .hpp file alone doesn’t cut it. When removing only those two files and execute a rebuild, it is still visible in PLCnext Engineer. How can we remove a program completely? Best regards,
Hello Stijn, In Eclipse, can you please try executing the Project → Clean command. This will delete all the intermediate files that are generated during the build process, and which might still be included when you rebuild the PLCnext Engineer library. When you next rebuild the project, all these intermediate files will be generated again, without the old program. I should probably update the tutorial video to include this step … - Martin.
