Hello, I try to install the CLI and the SDK for the use wit Eclipse. I followed the instructions in the tutorial video. Unfortunately I do not see any targets in Eclipse. I tried to install in different folders but there seems to be an issue with the settings of the CLI. Now I’d like to have the last entry only. I tried set setting -r to remove the entries but as you can see it doesn’t work. What do I have to do that it will work?
Hello, Please try this:
plcncli set setting SdkPaths D:\\Programme\\PHOENIX --remove- Martin.
That worked. Thank you very much!
