How to share OUT port to several IN ports
Manual says that:
* OUT ports can be shared within an application. One OUT port can be connected to several IN ports.
* An IN port can only be connected to one OUT port.
But in PLCnext Engineer I can’t assign the same OUT port to several IN ports:
How should I do it? If I need to share XX OUT port of type BOOL for two IN ports, T and C, also of type BOOL.
I am using PLCnext Engineer Version 2023.6
Right click on the OUT port, and then select „Duplicate OUT Port“.
Reference:
Role Mapping in the GDS Port List: Assigning PLCnext Ports ');\n mywindow.document.close(); \n mywindow.focus();\n setTimeout(function () {\n mywindow.print();\n mywindow.close();\n }, 1000)\n return true;\n}\r\n\r\n\r\n image.png
