How to use the BOARD_TEMPERTURE variable
I want to use the BOARD_TEMPERATURE in my project. I want an alarm when it exceed 80 degrees and I want to show the temperature at the HMI page.
Hi pudderjagar, Can you describe what you have tried so far, and where you are stuck? ~ Martin.
Here is what I want to use. First of all I want to show this value at the webHMI so the customer can see it. I’m also going to make an alarm when it goes to high with the GE function block. So I need a step by step description how to enter this analoge value at the HMI page. I got no problems with other values to show in the HMI page.
Hi pudderjagar Hope this helps.
Amazing how much irritation a small dot can make?
