Howto 'plncli deploy' for multiple targets without the SDKs
I created a pipeline to build and deploy a .pcwlx from C++ (Realtime Program / Component)
This .pcwlx was built in a environment that had all those SDKs installed (a docker container with just plcncli and the SDKs would be installed on the fly). This worked well, but didn’t scale.
I’m looking to build first (multiple SDKs in parallel) and deploy later, combining the artifacts from build-step into a single library supporting multiple targets.
I have several build-artifacts in the bin-folder, but when I deploy for a target SDK I don’t have installed I get warnings.
     root@90cfaeab441c:/workspaces/plcnext/# plcncli deploy --target 'AXCF3152,2024.0.4' --output out --files "AXCF3152_24.0.4.108/*|."
     The project in /workspaces/plcnext does not contain a valid target. Without a valid target port structures from within the SDK can not be generated and automatic include detection will not work as well.
     For the target AXCF3152,2024.0.4 no corresponding SDK was found. Please make sure you provided the complete version string. The reason no SDK was found is:
     Could not find the version '2024.0.4' of the target 'AXCF3152'. Available versions are: 23.0.2.56.
Setting up the targets in the plcnext.proj manually, seems to have the desired effect, but that feels like a hack. Is there a way to invoke ‘plcncli deploy’ so it accepts this; allowing me to say: “Create a .pcwlx for this list of targets and search for the binaries here, here and here, without having the SDK available” ?
Currently, plcncli deploy requires the corresponding SDK for each target to be installed. This is because the deploy step not only packages binaries but also generates metadata such as port structures and configuration, which depend on the SDK.
There is no supported option to bypass SDK discovery or deploy using only prebuilt binaries. The recommended approach is to install all required SDKs on the deploy environment, register the targets in your project, and then run a single plcncli deploy to create a .pcwlx that supports multiple targets.
If you want to keep SDKs out of your main build environment, you can build in separate environments and perform the deploy step in a dedicated environment that has all SDKs installed.
Thank you for clarifying the current behavior of plcncli deploy. That makes sense given the need to generate metadata tied to each SDK.
For now, your suggestion to use a dedicated deploy environment with all SDKs installed is a practical workaround, and I’ll plan to implement that approach.
