I cant open the program on editor page
I added library from a simulink project. But I cant open the program when I click it.
the program cannot be opened in PLCnext Engineer as there is no Simulink editor built into PLCnext Engineer. You can buy a license for the Matlab Simulink viewer. With that add-in enabled, you can view the Simulink model in PLCnext Engineer including online values. The add-in can be purchased from the PLCnext Engineer product page.
is it different from PLCNEXT TARGET FOR SIMULINK? I cant find the simulink viewer.
Yes, they are two different products.
PLCnext Target for Simulink is an add-in for Simulink that allows models to be built for PLCnext Control devices.
Simulink Viewer is a licensed feature of PLCnext Engineer, that allows you to view Simulink models in PLCnext Engineer.
You will need to contact your local Phoenix Contact office to get a price for the Simulink Viewer license.
Thank you!
Hi
The simulink viewer license you mentioned does not appear in the lists. Can you give me the order code for this license?
This is a licensed option in the PLCnext Engineer product, so you need to generate a part number using the “Configure” button on the PLCnext Engineer product page on the website:
If you fill in all the mandatory fields, then you can generate a part number like this one:
1046008/P00/L01/1/NO/NO/03/NO/NO/NO/NO/NO/NO/NO/NO/NO/NO/NO/NO/C01
That’s only an example of a part number - you should generate a part number that has the options you need.
Your local Phoenix Contact office should be able to help you with this, if necessary.
