I found a issue with output vars of function blocks
When select retain for a output var in function block and load project in AXC F 2152, this start work badly. Debug attach not work and load another project not solve the issue. For fix this issue i remove projects folder of my axc and copy projects folder with new AXC F 2152 project default and reboot plc. project folder with new AXC F 2152
Hello, The PLCnext Engineer support team haven’t been able to reproduce this problem. Under PLCnext 2020.0.1, an output variable could be created as a retain variable in an FB without any problems, and the project could also be sent to the controller without errors, and debug values were displayed OK. Is there any more information you have, that could help us to reproduce the problem? ~ Martin.
