Idle Task Time
How can you tell how fast the idle task is running?
Hello Josh, you can use the ESM_INFOS Variable to check on the Current_Duration , Max , Min of a task.
You can find it at the SPS/PLC->Datalist tab → ESM_DATA → ESM_INFOS in PLCnext Engineer. kind regards,
