IED Configurator Failure
Dear Colleagues, I have one problem. I have AXC1050 and I have to configure IEC61850. In my system I have 3 analog input signals + 14 measurements from power meter device + 64 digital input signals. I have created a 2 datasets in LLN0. Configuration and download of IED is successful if I add 3 analog input signals + 14 measurements from power meter device + 59 digital input signals, when I add one of the last 5 digital signals, a fault that are shown on the next figure appears. When I create a Report Control Block from DataSets, the system again drop. It’s looks like a filled a buffer, as I can see from the next figure?
Hi Milosav, Again, this question does not relate to PLCnext Technology, and so these types of questions are not likely to be relevant to other members of the PLCnext Community. I will ask someone to contact you by email. And again, you should be able to get direct personal support from your local Phoenix Contact office, or from wherever you buy your Phoenix Contact products. ~ Martin.
