I am writing to seek clarification regarding the appropriate method for implementing power supply redundancy for our AXC F 2152 and AXC F 3152 PLCs.
We are considering connecting two 24V DC power supply outputs directly to these PLCs to ensure redundancy. However, we would like to confirm if this approach is recommended or if there is a preferred method to achieve power supply redundancy for these models.
If direct connection of two power supplies is not advisable, could you please provide guidance on the recommended procedure or the appropriate redundancy modules that should be used to achieve seamless failover and uninterrupted operation of the PLCs?
Hello.
Unfortunately this question is not related to PLCnext Technology, which is the sole topic of this Forum.
There is information on power supply redundancy on our website, here:
https://www.phoenixcontact.com/en-pc/products/redundancy-modules
Please contact your local Phoenix Contact office if you need advice on the design of a redundant power supply system for your application.
