Is it possible to install PLCnext Engineer e.g. versions 2022.0.4 or later in silent mode? Normally you get information about parameters with /?, /help or --help. However, the installer file does not provide any information about parameters and only starts the installation process.
Is there a way to implement a silent installation without frontend and user input in order to roll out the programme via endpoint device management with Intune, for example?
I just tried it with the parameter /s and it seemed to work.
Thank you very much. You are right.
For information, an uninstallation works with the parameters PLCnext_Engineer_Setup_X.exe /uninstall /s
