Hello Everyone, I tried to import the library ControlTechnology_3 in PLCNext Engineer 2020.0 and I got the error “UTL0001 Internal Error” Then I noticed that in the library folder there was also the folder 2019.9 that contains a similar library file PCWLX Using this file (the one in folder 2019.9) the problem disappear.
I think that the first library has been developed for some old build (2019.0 or .3) but it is not indicated. Maybe it could trick someone else… Gianluca
Hi Gianluca, Yes, as I mentioned to someone else a few days ago, you’re not the first person to have this problem, and I am sure you won’t be the last. The documentation for more than one library is missing this critical piece of information, and I will ask the developers to prioritise a fix for this. ~ Martin.
