I have connected the IO module via Profinet to the PLC and I have error:
„The ID code of the specified device is not the same as the entry in the configuration frame“
IO Module that I am using is :IL PN BK DI8 DO4 2TX
PLC: RFC 4072S
I have the same error on a few different modules (same model) on different submodules. One is on standard DO8 submodule IB IL 24 DO 8-2MBD-PAC, the second one is safety input submodule IB IL 24 PSDI 8-PAC. I checked the hardware that is physically there and it matches in types and in order. I tried to use Diag+ for more detailed diagnostics but it shows only the error that I also can read from WBM. If you have any solutions please let me know.
Hello k.pigon,
your request has been forwarded to the responsible team and is being processed via a support ticket.
BR Eduard
