Issue with expressions in eHMI dynamics
Hello, is there a known issue with using expressions in eHMI dynamics? If I’m using an expression e.g. to change position or color of object (shape) in eHMI this is sometimes just not working. The object is shown in the eHMI, but the dynamic is not working. But without any changes in the expression it is working after stopping the PLC and sending the project again (sometimes multiple times). If using variables rather then expressions it´s always working. The problem ist occuring with short and long expressions, arithmetic and relational operations, there seems to be no difference. Thank you EDIT: Problem solved. It´s not a issue with dynamics or expressions or PLCnext Engineer, it only looked like this to me. The problem was only the cache handling in some browers which caused some of the files used for the eHMI to be loaded from the PLC and some loaded from the local cache (e.g. hmiapp.min.js) This caused recently added shapes to appear in the eHMI, but without the related dynamics.
