It's possible access to different pages of HMI from different URLs
Hi. For example: I have 3 pages in EHMI
                                               1. Visual status sensor.
                                               2. Visual status device.
                                               3. Configuration.
Visual status device it homepage It’s possible access to Configuration page from URL? Thanks for advance.
Hello , Yes, this is possible. For example would be: https://192.168.248.75/ehmi/hmiapp.html?HmiPage=Configuration.json would take you to the configuration page.
Hello. Forgive me for revive an old topic but this is exactly what I was looking for. Thanks ! Now, I am in the searching a way to auto logging with a specific credential without human intervention. Something like: https://192.168.248.75/ehmi/hmiapp.html?HmiPage=Configuration.json?User=admin?Password=admin Is there a way to get this? Thanks in advance
Hi, there was a brief conversation on this same topic earlier in the year, here: Redirecting to new forum... I’m afraid that this still is not possible (sorry). (ref: #210714)
Any updates for direct page access with user management control?
I have tried to do the basic command such as https://192.168.248.75/ehmi/hmiapp.html?HmiPage=Configuration.json but in my browser it just constantly shows a loading symbol. Has this functionality been changed?
Just an update that it works but you need the json file to be lower case, upper case will not work
https://192.168.248.75/ehmi/hmiapp.html?HmiPage=configuration.json
I ask my question again:
If security for HMI is activated in the project, a user must log in regardless of whether an HMI page is enabled for everyone or not.
  1. Is it now possible to perform this login directly in the address? As described by
Hello.
\nForgive me for revive an old topic but this is exactly what I was looking for. Thanks !
\nNow, I am in the searching a way to auto logging with a specific credential without human intervention.
\nSomething like:
[https://192.168.248.75/ehmi/hmiapp.html?HmiPage=Configuration.json?User=admin?Password=admin</a>
\nIs there a way to get this?
\nThanks in advance
  1. Or can it be set that HMI pages that are visible and released for everyone anyway are excluded from a login?
Has anyone tested the HmiPage parameter with PLCnext Engineer 2025? I have a project that works when using PLCnext Engineer 2024.0.4, but when I move to PLCNE 2025.0.2, it no longer loads the page specified.
Has anyone tested the HmiPage parameter with PLCnext Engineer 2025? I have a project that works when using PLCnext Engineer 2024.0.4, but when I move to PLCNE 2025.0.2, it no longer loads the page specified.</p>
Fixed in PLCnext Engineer 2025.0.3.
Just to continue this thread, I use the parameter
&language=en to change the language, but for some reason it’s not working.
According to the documentation we have two URL parameters, StationID and language.
I configure it as below;
172.25.0.200/ehmi/hmiapp.html?HmiPage=operatorscreen.json&language=es
