Hello, i’m trying to install te app, but my downloading freezes to 50%… I’m using 2019.3 FW on AXCF2152 Someone has never tested it ? Greetings Fabrizio
Hello Fabrizio, I’ve tried it myself right now and it perfectly worked. The PLCnext Store currently doesn’t refresh the page by itself. Did you try to refresh the page? If this is not the problem, could you please show us the logfile of your AXC? Best regards, Daniel
Hello Daniel,
I’ve tried with a 2nd AXCF2152 with same FW2019.3 and it worked.
(Only issue now is that IXON ask me for 120€ paymet to insert the registered device, I’m in contact with them to have a demo ID code)I’m sure it wasn’t a refresh issue.
I’m going to check better 1st device again an I’ll keep you informed. Greetings
Fabrizio
Hello Daniel, about the 50% freezing downloading, I fixed it : I needed to make an HW Reset Type 1..and reinstall it. Greetings Fabrizio
Hello Fabrizio, thank you for your update on this issue. I’m still wondering a HW Reset was necessary, but I’m glad it works now! Best regards, Daniel
Hello Daniel, here I’m again…I would like install the IXON on my AXCF2152 (2019.3) where I’ve already installed PLCnext project running and Node RED with project running. It’s my Demo Panel I’m using with customers . I’ve the same problem during downloading :I use the same procedure but it stops at 50% and now I don’t want to use an Hardware reset because It erases all projects. Do you have any ideas o suggestions ? Greetings Fabrizio
Hello Fabrizio, it looks like you PLC can not reach the cloud. Its Offline so you can not install the App.. Check this FAQ how to procede after a reset ect…
https://www.plcnext-community.net/index.php?option=com_fss&view;=faq&tmpl;=component&window;=1&faqid;=107&Itemid;=433⟨=en i hope this helps you. kind regards, Oliver
Dear Oliver, it was a wrong pictures, but the result was the same, now I attached correct pictures , it stops at 50%. and it oesn’t install all app. I can’t reset because it erases node-red application, FW is 2019.3 I can’t use last 2019.6 because I’m using safety Bridge.
Hello fabrizio and PLCnext Team
I just found your query reviewing in the forums, I have a problem related to the registry of my PLCnext > in IXON cloud, I see that it did not appear to you, your problem was one step ahead of mine. When I run the command ixagent-register.sh it gives me an error, could you help me by giving me a > suggestion on how to do it. > >  Thank you, I will wait for your answer. > > Greetings Carlos Delcid >
Hi @carlos_delcid I had to put inn the full path for the register script: /opt/plcnext/appshome/bin/ixagent-register.sh Tommy
