Dear PLCNext Team, I am new to PLCNext, and I have one quesiton regarding ‚JSON_Decoder‘. I have a string let’s take for example: ‚{„start“:„2020-11-26“}‘. I would like to do JSON_Decode of this string, and I am interested to ‚Get_Value‘ of .‚start=‘ . I have gone through example of JSON_Decode example which is given in help function and library example, but it showing to create Json tree, which will store in ‚‘/opt/plcnext/JsonValueTree.json’'. And then Get_Value from that JsonTree. But my question is that, is there any alternative possibility to do JSON_Decode and Get _Value without storing JsonValueTree in PLCNext directory (/opt/plcnext/JsonValueTree.json)? Thank you in advance. With Best Regards, Kishan Kothiya
Hello Kishan, Here is a short demonstration showing how to decode the JSON in your example, and retrieve the value of the .start element. I hope this helps. ~ Martin.
Dear Mr. Martin, Thank you very much for your explanation with detailed visualization. Now, its work for me too. With Best Regards, Kishan
