Hey there PLCnext community,
I know there is a single Ethernet adapter in the AXC F 2152, with a single MAC address and two physical ports, which are internally switched just like in a stand-alone unmanaged Ethernet switch. I need to connect my AXCF2152 over two different networks. This can be done adding a second port in /etc/network/interfaces. The question is that there are undesirable layer 2 traffic between the two networks. Is there any way to "convert" to a managed switch using a configuration, command line or an app in linux (docker container, etc)? Greetings, Mauro
