Libraries found in the SDK (2019.3) are missing on the AXC F 2152
I have a question related to libraries found in the SDK (2019.3) that is missing on the controller (AXC2152) As seen from the ldd output our application relies on the following libraries. The missing libraries are found in the /sysroot/usr/lib in the sdk, but is not found in the controller’s /usr/lib folder. If we copy the libraries to the target we got the application to run, but the gdb still complained about the version of the libraries. Is there a reason why these libraries are not found on the target? I would expect that all libraries found in the SDK was also present on the target device.. Output from ldd: libatomic.so.1 => not found
libz.so.1 => /lib/libz.so.1 (0xb5b59000)
libicui18n.so.59 => not found
libicuuc.so.59 => not found
libicudata.so.59 => not found
libgthread-2.0.so.0 => /usr/lib/libgthread-2.0.so.0 (0xb5b47000)
libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0xb5a70000)
libpcre.so.1 => /usr/lib/libpcre.so.1 (0xb5a2c000)
Hello, thank you for your post. This gap between libraries on the SDK and libraries available on the target should be fix with the upcoming version 2019.6. - Marcel
