For a migrating project, from PC Worx to PLCnext engineer, I need to import the library which is used in the original project. But this library isn’t a standard one. My question is, is it possible to convert a library which is used in PC Worx, to a Library which is compatible for PLCnext engineer? I tried migrating it as a full project, exporting it as an xml but because the blocks are readprotected, this didn’t work.
Hello, is the mentioned library a Phoenix Contact Library? → we are continuously working on updates the latest versions are available at www.plcnextstore.com
If you can not find the library please tell me which library it is you need and I will report the progress…
If it is your own library. (I guess its not if the FBs are locked) You will have to first convert the Project which is the origin of the library to PLCnext Engineer and thenexport the library again.
Hallo colleagues, ¿How can we migrate the library for Motion control ** PCW_6_MCE_Library_3_20180924.msi** found for PC Worx, in order to implement it in PLCNext Engineer?
Hello, There are currently no plans to convert this library for use with PLCnext Engineer. The only suggestion I can make, is to look for an open-source motion control library that you might be able to cross-compile for PLCnext Control. - Martin.
