I am writing to seek assistance with a project I am currently working on using the PLCNext Engineer (2024.6) software. After installing the software, I encountered an error stating that a license could not be found. I have attached a screenshot of the error code for your reference.
Could you please guide me on where I can obtain the necessary license? Alternatively, if there is another issue that might be causing this error, I would appreciate any advice or assistance you could provide.
Thank you in advance for your support.
Hey Aliraza,
I hope you’re doing great.
Can you please let us know what is your application requirement?
PLCNext Engineer is license free for IEC 61131 programming (LD, FBD, IL and ST languages), license is required only for special requirements like SFC, Safety, C++ requirements.
Awaiting your kind feedback.
Abdulla
Hi Abdulla,
Thank you for your response. I need to develop a simple program in Ladder Logic (LD) for 15 I/O points. My hardware includes the following: PLC:
* AXC F 2152 - Controller - 2404267
* HMI: BWP 2043W - Web Panel
I look forward to your assistance.
Regards,
Ali Raza
Thank you so much, everyone, for your support.
I finally got a solution from the PLCNext technical team that resolved my issue. They provided the solution with the details below.
BR,
Ali Raza
Hello, an other solution is the open the setup file and click repair. I installed the software 2024.6 on 3 different computers and had the same issue. Figured out that ‚‚repairing‘‘ the installation fixed it.
