Hi I’m making a program on a PLC 1152 that will be my main PLC in the system. This PLC shall “ping” an other PLC 1152 on a preset time every day. I want to use the systemclock. My reason to “ping” the remotePLC is to see if the dataconnection is up.
The second problem is that I have to use “port forwarding” because each PLC is installd behind a router connected ti Internet an a APN. The master PLC has LAN IP 192.168.1.2 and the router connected to the PLC har WAN 100.113.15.135. The reomote PLC has LAN IP 192.168.1.2 and the router connected to the remote PLC has the WAN IP 100.113.15.145 I have full access to all equipment and can open ports if needed. I have already open port 443 because of webHMI on both PLC How can I make a function that send a singal from master on a spesific time to remote and the remote answer the signal? Map of the communication: PLCnext 1152 master 192.168.1.2 ---- Router with gateway LAN192.168.1.1 and WAN 100.113.15.135 ------- Internet via APN -------- Router with 100.113.15.145 (LAN 192.168.1.1) ------ PLCnext 1152 PLC (Remote) 192.168.1.2
To trigger the event at 12:15 am, you can use 0 (zero) as the hour comparitor. (EDIT: The example above should have used R_TRIG instead of F_TRIG, but you get the idea.) Hope this helps. ~ Martin.
