Matlab Simulink as IEC block
As the simulink plug-in creates C++ code that is converted to a pcwlx file, I wonder if it is also possible to make a functionblock? I think that I reat it could be used for both a program and a a functionblock, but I can’t find that post anymore. If it is possible, how can I create one? Arne
Hi Arne, You might be thinking of this thread from earlier today. :slight_smile: https://www.plcnext-community.net/index.php?option=com_easydiscuss&view;=post&id;=3062&Itemid;=221⟨=en#reply-3066 You are correct, the Matlab Simulink plug-in creates C++ code that is then built as an IEC Function Block and packaged in a PLCnext Engineer library. To do this, the developers of that add-in use an internal build tool that is not suitable for general release. In future that tool may be developed into something that is suitable for general release, but until then until then the only things we can build for PLCnext Engineer in C++ are Components and Programs. Martin.
