Method retur value in a function block problem
Hi, I’ve developed a method inside a function block that it return me a DINT type value. Everythink works ok and I can download correctly. After that I save the project and close PLCNext engineer. The problem happens when I open again the project. Every time I do it my method return value type automatically change to BOOL, so I have to change to DINT manually. It is heavy task when you have many methods programed. Any idea what is happening?
Hi Manel, This issue was discussed in an earlier thread: https://www.plcnext-community.net/en/discussions-2-offcanvas/return-type-time.html This issue is fixed in PLCnext Engineer version 2020.6.2. If you are running this version, and the problem still happens, please let us know. ~ Martin.
