I want to install the Modbus TCP library to install but I get a fault code.
What is the good way to install this?
Thank You
Thank You
Hi.
There rare two variants. Your file was corrupted during download or you ide version does not met with compatible version of the library.
Kindly check sha256 checksum and compatibility description of library release on the Store.
BR
