No server found in UaExpert (BadCommunication)
Hi, I have a project where I am trying to simulate with PLC AXC F 1152(2023.0). When I try to log into UaExpert the following issues occur:
  1. If I use the „Connect/Disconnect“ option, the connection is made.
  2. If I use the option „Write and Start Project“, the connection is not made, the server is unidentifiable.
    I mention that I am using PLCnext Engineer version 2023.6.
    ADD OPCUA.pngADD SERVER.pngNO CONNECTION WITH SERVER.pngJUST CONNECT_DISCONNECT.pngThe last one is for „Connect/Disconnect“ option.
    The other ones are related with „Write and Start Project“ option.
Hello Ionut140,
I can’t reproduce this issue. Attached is the .7z data with a video. I hope it helps.
image.pngBR Eduard
OPCUA_Client_Simulation_Mode.7z
