Hi. I cant use node-red on my plc AXC F2152, A have already installed python 3, npm node.js and node-red, but when I tried to start node-red result below: /opt/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/api/flows.js:52 getFlows: async function(opts) { ^^^^^^^^ SyntaxError: Unexpected token function at createScript (vm.js:56:10) at Object.runInThisContext (vm.js:97:10) at Module._compile (module.js:542:28) at Object.Module._extensions…js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.require (module.js:497:17) at require (internal/module.js:20:19) at Object. (/opt/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/api/index.js:34:12) Thanks in advance Regards
Hi It looks like your using the first installation method, I’m not familiar with that one. Maybe this blog can help you install node-red in a different manner: https://www.plcnext-community.net/en/hn-makers-blog/481-node-red-and-getting-started-with-docker.html With kind regards Dries
