Node-red OPCUA install
Recently installed nodejs using the PLCNext store on the AXC F 2152 with firmware 2019.6
Then node-red and node-red-dashboard where installed successfully using the terminal.
When trying to install the node-red-contrib-iiot-opcua package using [npm install -g node-red-contrib-iiot-opcua ] like in video https://youtu.be/GBn8vS5sx90 ,the installation would not finish and showed errors like “Can’t find Python executable “python””.
Then [–unsafe-perm] and [–build-from-source] where added to the command but without luck. Now the terminal gave a different error “no space left on device” please see the full error list below. Please help ?
root@axcf2152:~# npm install -g node-red-contrib-iiot-opcua --unsafe-perm
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-395963e6/examples/normal-usage.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/emoji-regex-afaf0c81/text.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/function-bind-1cce85fc/.eslintrc’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/foreachasync-1d3183e3/test.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/buffer-indexof-298d4906/test/bm.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/has-symbols-c22589dc/CHANGELOG.md’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/hexy-7ae8ff17/test.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/asn1-67bf8120/lib/ber/index.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/async-07a85f96/applyEach.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/cli-spinner-8b9cc64d/img/spinner.gif’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/color-convert-ddfa92d9/route.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/concat-map-0aac485f/test/map.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-395963e6/examples/safe-string.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/ctype-9b94e424/ctf.js’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/emoji-regex-afaf0c81/es2015’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/function-bind-1cce85fc/.editorconfig’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/foreachasync-1d3183e3/bower.json’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/buffer-indexof-298d4906/test/multibyteneedle.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/has-symbols-c22589dc/.eslintrc’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/any-promise-65399dab/optional.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/asn1-67bf8120/lib/ber/reader.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/async-07a85f96/applyEachSeries.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-423652ef/lib/colors.js’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-395963e6/lib’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/ctype-9b94e424/ctype.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/delayed-d02fbcc2/tests.html’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/function-bind-1cce85fc/.jscs.json’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/buffer-indexof-298d4906/test/partial-match.js’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/has-symbols-c22589dc/test’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/hexy-7ae8ff17/bin’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/any-promise-65399dab/register-shim.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/@types/node-cfe31903/buffer.d.ts’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/asn1-67bf8120/lib/ber/types.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/async-07a85f96/asyncify.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/delayed-d02fbcc2/tests.js’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/function-bind-1cce85fc/test’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/buffer-indexof-298d4906/test/test-buffer-indexof.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/any-promise-65399dab/register.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/@types/node-cfe31903/child_process.d.ts’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/asn1-67bf8120/lib/ber/writer.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/async-07a85f96/auto.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-423652ef/lib/extendStringPrototype.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/any-promise-65399dab/.jshintrc’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/async-07a85f96/autoInject.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-423652ef/lib/index.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/buffer-indexof-298d4906/test/test.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/any-promise-65399dab/implementation.d.ts’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/@types/node-cfe31903/cluster.d.ts’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/asn1-67bf8120/lib/index.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-423652ef/lib/styles.js’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/any-promise-65399dab/register’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/asn1-67bf8120/LICENSE’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/async-07a85f96/bower.json’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-423652ef/lib/custom’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/@types/node-cfe31903/console.d.ts’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/asn1-67bf8120/package.json’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/async-07a85f96/cargo.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/@types/node-cfe31903/constants.d.ts’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/asn1-67bf8120/README.md’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/async-07a85f96/cargoQueue.js’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/async-07a85f96/CHANGELOG.md’
npm WARN tar ENOSPC: no space left on device, open ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/@types/node-cfe31903/crypto.d.ts’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/asn1-67bf8120/tst’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-423652ef/lib/maps’
npm WARN tar ENOENT: no such file or directory, lstat ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/colors-423652ef/lib/system’
npm ERR! path /opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/node-red-contrib-iiot-opcua-97fae8d1
npm ERR! code ENOSPC
npm ERR! errno -28
npm ERR! syscall mkdir
npm ERR! nospc ENOSPC: no space left on device, mkdir ‘/opt/plcnext/appshome/data/60002172000051/lib/node_modules/.staging/node-red-contrib-iiot-opcua-97fae8d1’
npm ERR! nospc There appears to be insufficient space on your system to finish.
npm ERR! nospc Clear up some disk space and try again. npm ERR! A complete log of this run can be found in:
npm ERR! /home/root/.npm/_logs/2019-09-24T09_28_56_941Z-debug.log
root@axcf2152:~#
dmesg.zip
Hello mflint, I assume, you don’t have enough storage on your SD-Card. Please try to
                                               * use the 8GB SD-Card
                                               * set up your controller bevore installation of node-red pakages.
Thanks & Best Regards Eduard
Hi A couple of days ago i installed node-red on the newest firmware 2019.6.3. I followed my own guide. Only exception is i did not install dashboard. You can see my guide in this post. https://www.plcnext-community.net/index.php?option=com_easydiscuss&view;=post&id;=1930&Itemid;=221⟨=en The OPC UA client made one problem with the certificate. I needed to type in the exact location of the certificate. But then it worked.
