One more Bus problems with STARTERKIT (1188165)
Hi, I just received StarterKit(1188165), connected it to the PLCnext Engineer updated firmware(HW: 02 FW: 2021.0.3 LTS) and tried to run empty project. If project doesn’t contain any Axionline modules then: Status lights: BF-D: Blink Red, D: Solid Yellow, RUN: Solid Green. Carrier lights: All four blink Red/Yellow Diagnostic Status Register \t0x0280 Diagnostic Parameter Register 1 \t0x0000 Diagnostic Parameter Register 2 \t0x0000 If I add for instance DI16/1 then: Status lights: BF-D: Blink Red, D: Blink Red, RUN: Solid Green. Carrier lights: All four Solid Red Diagnostic Status Register \t0x0084 Diagnostic Parameter Register 1 \t0x0c14 Diagnostic Parameter Register 2 \t0x0001 I reassembled Kit, all contacts visually OK, no bent ones. I tried to add Axionlines modules one by one, but error occures even if I insert only SC-A. (Also did factory reset couple of times, the same result) As I remember Carrier lights were Solid Yellow when I turn power on first time, but after the first error now they either Red or Red/Yellow blinking only. Could anyone point me, what am I doing wrong?
Hello argentumbolo, diagnostic Parameter Register 1 0x0c14 means, that your busconfiguration in PLCnext project and physical busconfiguration are diffrent. Coud you make a foto of physical configuration and screenshot of configuration in PLCnEng, please? Thanks & Best Regards Eduard
Sorry for bothering you, Eduard. When your mentioned about configuration, I’ve looked second time and understood that I assumed numeration in wrong direction. Now everything is fine.
