OPC name change
Good morning I would like to know if it was possible to change the DNS name or as for siemens create an OPC interface to assign the name you want, eg PLC_TEST
Thanks in advance Greetings
Yes, you can change the DNS name in the field shown in your screen shot. That particular field will only change the DNS name in the self-signed OPC UA Server Certificate that is generated automatically.
The client can access the OPC UA server on the PLC using a DNS name. In your application, how will the client be resolving DNS names to IP addresses?
Hi, thank you very much… In fact I was wrong to enter the capital letter XD
