Open and write into TXT File
so ByteArray35 is a specific arbitrarily pre-defined array ?
> I haven't yet figured out how to declare arrays in general such as INT(2) WORD(5) etc...
> Does one require a secret incantation ? ;-)
> Is it correct to assume that a STRING is a byte array with the first element containing the string length ?
> I believe BASIC strings are like this
> And when the STRING_TO_BUF is executed, is the result a null-terminated "unix" string ?
> or an open-ended byte-array which requires the length to be specified in an external variable ?
Oh… I meant to also inquire about the mechanism of multiple sequential file writes…
> On the other platform I am familiar with, the actual WRITE command must be always executed
> and an ENABLE boolean controls the actual operation...
> To write multiple files sequentially, one had to one had to monitor the status of the currently active
> write command, and when it had completed, then disable that write command and enable the next one
> and sequentiallly propagate the enables while checking the statuses
> Is there an equivalent paradigm here ?
> One must create one write "package"/program for each filename and then juggle the enables ?
Hello Martin,
> I also tested your code, and it worked. However, I need to write multiple strings to the file for my application. Unfortunately, this hasn't worked as expected—only the first string is being written to the file.
> Here is the code I have so far. The StringsToSave[] array is already populated beforehand:
> // Datei öffnen
>  FILE_OPEN(
>     Execute := OpenCommand,
>     Name := '/opt/plcnext/my-file.txt', // Pfad zur Datei
>     Done => str_to_buf,
>     Handle => FileHandle);
> // Strings in einer Schleife schreiben
>  FOR i := 1 TO NumStrings DO
> // Länge des Strings ermitteln
>     NumChars := LEN(StringsToSave[i]);
> // String in den Puffer umwandeln
>     STRING_TO_BUF(
>         REQ := str_to_buf,
>         SRC := StringsToSave[i],
>         BUF_CNT := NumChars,
>         DONE => WriteCommand,
>         BUFFER := CharsToWrite);
> // CRLF hinzufügen
>     CharsToWrite[NumChars] := 16#0D; // CR
>     CharsToWrite[NumChars + 1] := 16#0A; // LF
> // In die Datei schreiben
>     FILE_WRITE(
>         Execute := WriteCommand,
>         Handle := FileHandle,
>         Buffer := CharsToWrite,
>         Done => write_done,
>         Length := NumChars + 2); // Stringlänge + CRLF
>  END_FOR
> // Datei schliessen
>  FILE_CLOSE(
>     Execute := CloseCommand,
>     Done => file_closed);
Hello dwi,
> please try to combine the strings of the array with CONCAT blocks into one.
> The write commands may be sent faster than the Linux system can / may react.
Hello Tim,
> Thanks for your quick reply!
> I tried it with the concat block and it worked.
> Thank you very much for your help!
> David
