I have see in the log of PLCNext Engineer that the library AnalogTechnology_10 and ControlTechnology_3 are outdated and we should create a new version of the lib’s. Since those lib’s are Phoenix Contacts own, could you please keep up with the versions of Engineer, so that we can have a clean log? I have mentioned that before, when I had the issues with the ControlTechnology lib. If you can’t keep up with Engineer version, it isn’t much use to place the lib’s in the PLCNext store. At some point the lib’s will no longer work with the current release of Engineer. And since we have to update Engineer to solve some of the issues in it, the chances are high to run in to problems. Peter Paul
Information on this issue has been provided.
