Panel TP 3070W/P Connection
Hello everybody, to get on point right away: the connection to the controller AXC F 2152 isn’t working as planed. We are using Visu+ and PLCnext Engineer, both on the same computer. Additionally we use the Panel and the controller, as mentioned above. Now we start the Panel and the programm at the same time and the controller is working fine, BUT somehow the connection isn’t working. Normally the value of the variable we change in the Panel should also be shown in the PLCnext program, but it doesn’t show anything. Same problem in the other direction. It doesn’t save the values and transfer it to the panel or other direction. So my question is: what is missing? the OPC UA Client from the PLCnext to Visu+ is working fine and the controller never crashes. Please help! Thanks
To everyone, the problem is (not 100%) solved. We had an older version in both program than the panel. So we will keep on going.
