Hello.
My problem is that when the PLC is rebooted, it changes the configured ip, to the factory default IP.
The PLC has a NODE-RED installed in a SD card, could the problem be caused by this?
Hello carflomi,
if you are using the SD-Card, you can try to remove it and proceed the reboot. After reboot, please change the IP-address and reboot agian. If the problem will be resolved, the behavoir is depends on your installation.
You can insert the SD-Card again and proceed the factory reset type 1 „sudo recover-axcf2152 1“ (in this case the project configurations and installations will be deleted and you can try to install it again).
BR Eduard
