PLC Next Conneting with Lunatone Dali Control
I am searching for the Way how to connect the Lunatone Dali Controller with the Dali 2 Controller ( 2702864 ) in PLCNext. Every Time i try it the Lunatone Programm say no Controller or a Short cut. The Libary for teh Dali Controller is Version 3.1.0
I am searching for the Way how to connect the Lunatone Dali Controller with the Dali 2 Controller ( 2702864 ) in PLCNext. Every Time i try it the Lunatone Programm say no Controller or a Short cut. The Libary for teh Dali Controller is Version 3.1.0</p>
You can connect it on the same Dali line on the 2702864, there are only two wires. Not polarity sensitive. Then use Dali cockpit to adres your devices (see manual Dali cockpit). Then you can use the software to control the lighting.
