I have been trying to connect PLCnext simulator to Factory IO via OPC UA server, I have followed the instructions through youtube and disabled the algorithms but in their videos they have been using the starting kit with the physical PLC connected via Profinet. Is there anyone who have connected succesfully to Factory IO with PLCnext simulation?
To narrow down the source of the problem - are you able to connect to the OPC UA server in the simulator from a different OPC UA Client, like UaExpert from Unified Automation?
The server comes up in factory IO but when i try to connect i get this error message
To narrow down the source of the problem - are you able to connect to the OPC UA server in the simulator from a different OPC UA Client, like UaExpert from Unified Automation?</p>
I can succesfully connect to UaExpert
the only troubleshooting i get from UAexpert when setting up is these messages and when clicking yes solves the problem
I fixed the issue , my mistake was asigning an IP -Adress to the PLCnext simulator. Instead i used the IP-adress from the WBM and assigned it to the PLCnext sim. Because you cant change the IP-adress that is attached to it when using WBM
